Hi guys. I am not member. Could you help me to sort one problem. I need to test my design and I need to use the signal generator. My one broke down and the service told me that I will have to wait several weeks before it is ready. I Literally need to connect a sine 1-2MHz sine signal for 10 seconds to see if the software is calibrating the device . Could you help me sort it out.
I’m not really familiar with Joe’s test equipment but the equipment here is definitely capable of generating such a signal… The big HP signal generator isn’t connected, is under a pile of heavy gear and I’m not even sure where the right cabling for it is.
I cursory look over the other smaller units do not go as high as 1 Mhz unfortunately.
I have a DDS module with me right this moment that can generate a squarewave from 8khz up to 160mhz. That plus a low pass filter circuit would be capable of providing a sinewave in the desired range.
I’ve been here all night though so not looking to commit to hanging around too much longer.
