I have noticed the air compressor is not working, the machine has power but it toggles to the off mode after switching the power on at the wall. If anyone is aware of the fix please discuss as it’s best if several people are aware. By all means take a look in the wood shop if you possess the relevant skills to diagnose the issue.
Compressor doesn’t work
Probably just switched off just lift up the red button
I will have a look at it tonight hopefully
Yes it’s working again, thanks. So the red button needs to be lifted up that’s good to know.
