Tormach 770
spec sheet
https://www.tormach.com/uploads/1097/tormach_pcnc770specsheetv2_FORWEB-pdf.html
Travel X/Y/Z: 355mm x 190mm x 336mm
spindle speed 1hp, 10,000 rpm
hand-scraped ways
Base model is $6850 with manual oiler
Costed with vise, tool holder and Z calibration kit, chip pan + stand, enclosure, path pilot software (much better than mach 3), shuttle dial, manual oiling system and machine oil:
-with no other options: $10,344
-with 4th axis and tail stock: $11,858
-with power draw bar (needs a compressor): $11,711
-with both: $13,500
fog buster mist coolant system add on is $395, flood is a bit more I think.
Tormach 440
spec sheet
https://www.tormach.com/uploads/943/tormach_pcnc440specsheet_2016FORWEB-pdf.html
Travel X/Y/Z: 250mm x 158mm x 250mm (same size as Joe’s yellow mill)
spindle 3/4hp, 10,000 rpm
hand scraped ways
base model is $4,950
with stand, chip pan, enclosure, 4" vise, tool holder and Z calibration kit, path pilot software, machine oil, shuttle dial:
-with no other options: $9,432
-with power drawbar: $10,127
-no 4th axis option
##Sieg KX3
specs:
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/CNC-Milling-Machines/Sieg-KX3-CNC-Hobby-Mill/Sieg-KX3-Hobby-CNC-Mill
travel X/Y/Z: 295mm x 150mm x 275mm
spindle 1hp, 5,000 rpm
base price £5,415.49 inc vat
with mach 3, vise, and machine stand:
£6,065.68 inc vat
with 4th axis options:
4" rotary axis: £6,480.57 inc vat
6" rotary axis: £6,675,51 inc vat
no tail stock available for the 4th axis (we’d need one)
a guy on youtube got a deal on his 4th axis, making it free, might be able to bargain with them?
no power drawbar options
no Z-calibration system
collets and toolholders will be extra
delivery is £65
