CNC Mill - Inventables Shapeoko 2
Tags: #<Tag:0x00007fa496691a08> #<Tag:0x00007fa4966918c8>
eg. Manufacturer, model, capabilities. Include a photo.
Condition Notes
On loan from @bmsleight
Induction and Training
Owners
List of @usernames who are responsible for maintenance
Risk Assessment
Identify risks
State control measures
Before Use
The origin needs to be set using g-code:
  1. Make sure the black box is powered.
  2. Connect USB to computer of your choice, making a note of the COM port that is being used (e.g. COM 1 or /dev/ttyACM1)
  3. Start the Universal G-Code Sender
  4. Position the end mill either manually or with g-codes e.g. X3, Y4, Z5, etc.
  5. Make a note of the coordinates.
  6. Send g-code G10 L2 P1 X3 Y4 Z5 - where 3, 4 and 5 are the actual coordinates.
  7. GRBL (the Shapeoko Arduino shield CNC controller) now sets the current position as the origin.
  8. Double check by issuing commands such as Z-1 and Z1 to make sure origin has been set.
Once the Shapeoko has registered the new origin, it is possible to change all axes manually e.g. by turning the Z axis flexible coupling manually.
During Use
After Use
Maintenance
References
