Description of storage request
CNC Lathe - Frame Build
Storage Location
Next to wash bay
Start Date
2nd January 2020
End Date
30 April 2020
Storage Location
Next to wash bay
Start Date
2nd January 2020
End Date
30 April 2020
Hi,
This is a very long storage request. Is there a reason the build needs four months? It would be useful to add that information.
This area is intended as an assembly area for active projects in the final stages of construction – usually a table or bed that’s being glued/finished for example. So there needs to be a good reason for a project to be there, as everything else should be stored in the Snug
Also: can you add dimensions so we can work out the feasibility of this for the Messy Room
I expect it to take two to three months the rest of the time is contingency
It about the same size as the dalek (slightly wider) and wont be at the arch nearly as long, Calum has used the same space for a scale also similar in size and other bit in the same place
It needs to be laid out as it is worked on (it is a as built construction) to fit the bits used rather than a prescribed design
