I can see that I will need to provide a bit more background so that we don’t end up going over well trodden ground.
I’ve read Ignition; you have to take everything the Americans say about peroxide with a whole mine full of salt. After WW2 we in this country became the world authority on catalysed peroxide engines. In 1971 we launched a satellite, Prospero, using the Black Knight rocket powered by Bristol Siddeley Gamma engines. These catalysed peroxide (90%) through silver plated gauzes and then injected kerosine into the superheated steam and oxygen stream that resulted.
In 1988 David Andrews, one time chief engineer of the Gamma project wrote in a JBIS paper on Black Knight that:-
With regard to silver or silver nitrate as a catalyst, I’m trying to avoid this as it is very expensive. The Germans used a 27% solution of sodium permanganate in water to catalyse hydrogen peroxide in the steam generator of the V2 missile. Steam generator output drove the turbine that ran the pumps for the fuel and oxidiser, namely LOX and ethanol. An excellent description is given in the report on Operation Backfire, downloadable from the Smithsonian.
To reiterate, I’m looking at a slower, more modest scale reaction using the 35% peroxide which is much safer to handle. I’m hoping I can make a unit that could drive a small turbine to give usable power.
I’m also very interested in the ethylene or propylene glycol/permanganate reaction. A good rocket engine igniter could lie in the idea of injection of glycol and permanganate solution, the flame from which could then ignite the main propellants.
