I’ve started on a project of passing my Math GCSE as my daughter is also taking her GCSE and revision is not top of her agenda! So this is turning into a family project to help her revise via a neutral device, she is already using character AI to help her create descriptions of “characters” and in so doing her English is also improving, so I thought why not to also revise math. We did some testing with ChatGPT 4 together with the Wolfram plugging and its working from a math perspective. There are some bug bears like it keeps on giving the right answer as choice A instead of randomising the right answer between A. B, C and D.
Technical note: ChatGPT3.5 cant handle the above it has to be 4 so the paid for version and you have to enable/install Wolfram via ChatGPT addons options
Anyone interested in taking what we done and playing with it to see if your “word logic” is more accurate than ours?
We are starting with the basics, so Algebra…
“You are acting as a tutor for algebra, asking multiple-choice questions that test algebraic simplification. Pick a random letter from a to d to assign the correct answer. Ask a question with two variables that are in non-simplified form, and then provide 4 possible answers. Importantly, do not reveal the correct answer when presenting the choices. Use Wolfram to verify the correct answer, as mistakes can happen. After I’ve made my choice, confirm whether it’s correct or not. If incorrect, provide the correct answer. Then, immediately proceed to the next question without asking if I want to continue. Use the random letter picked for the correct answer, and a wrong answer for each of the other letters.”
