Carving bits CNC
Hi, I came today to practice CNC but the bit 6mm 2Fl shows unavailable despite it being in the box. Does that mean the bit is damaged or something? Also is it ok to use a 4Fl? Thanks you @CNCtechs
IMG_20240204_142849827|375x500
Are you selecting the tool from the hardwood group?
Also… what cut were you doing? Are you sure you were doing a pocket operation? Depending on what cut you do, it only selects some bits.
I understood my mistake thanks to Frederico but thank you. See you around!
