I’ve just come to use the big CNC and it seems it’s unable to home. I turned it all on, connected from LinuxCNC, clicked “Home All”, the spindle raised and then seems to be trying to home but is hitting the limit, making a horrible noise in the process. I hit the Estop
The limit sensors look to be clean. I tried it again and the same happened. I’m unsure of if it’s making the noise when it gets to the limit or if it is making it all the time when trying to travel in X direction.
I’ll put an out of order sign on it until the @CNCtechs can take a look.
Ok… Wow never happened before… We need to check on the machine. Please anybody else who used it last ( other than James)… Any weird behaviour to report? They could be related
It moved past its limit switch and must have tried to engage against its physical limit when running the homing routine but not detecting the limit of the y axis.
