Big CNC keyboard dead
@CNCtechs When I turned on the big CNC today the keyboard wouldn’t work at all (no power, tried KVM switch etc). Didn’t want to mess around with the cable management, so I borrowed one from the front room (from a @systems stash maybe?) and have left it plugged in for whoever uses next. Hope that’s OK!
All good, yes the ones above the workstations are for just this case!
Cheers
Thanks for fixing it @sarab.sethi
You’re welcome - but to clarify it’s currently a half fix with the broken keyboard still attached (but moved backwards) and the new one plugged into the usb port in the front. So someone who knows how the kvm is all wired up will have to do the full switchover still!
