Looking for advice on small speakers as I have practically no exp with this side of electronics.
My plan is to code up a Arduino Nano with an MP3 file that activates through a miniature speaker when a button is pushed.
Pretty simple and I have made similar code before so that side of things should be all good.
That said I have no idea on where to start with small speakers outside of Maplins, and I know they will charge more for the convenience of walking in and looking around (which is fair) and only have a very limited range. Ideally the speaker will need to fit within a 2cm diameter space, but I can make slight adjustments to this if needed.
Any ideas on websites or brands that I should be looking at please get in touch
How are you playing the MP3 back on an Arduino as they don’t have w codec for that. It’s technically possibly to play a WAV file from an SD card but not an MP3.
Otherwise you should be able to drive a small speaker from an Arduino directly, but if you want to amplify it and improve the sound quality various filtering and amplification parts are needed…
@lewisss and @joeatkin2 live a secret double life in electronics when away from the wood workshop, and would be worth consulting!
Doubtful you can upload a file to it… they come with a mic so you just play what you want on a pc or phone and put the mic right up to it, sounds fine actually… a bit more old school than uploading tho
You could cut a 3.5mm headphone jack and wire up directly instead of the mic I would think to send a signal directly in for recording…
Either way good cheap way to make a gift, can embed in virtually anything and swap the speaker out for a different one if you like, the one I used was plenty loud with a better speaker hooked up!
Can’t really say what it’s for just yet, but basically it’s going inside a square tube. The tubing will be designed and 3D printed by myself so I have a bit of free reign. However it’s going to be a mock up of a static object that exists so i’d prefer to not deviate from the size too much.
Ideally you would push a button on this tube and it would play sound 1, push it a second time to play a different sound 2, repeat.
If val = 1 then play File1 and + 1
If val = 2 then play File2 and - 1
It’s going to be enclosed so the visual appearance of the components wont matter.
Depending on how lofi is acceptable you could try this setup. Basically it’a piezo, DFPlayer clone and Arduino Compatible NodeMCU, with pins D2 and D1 on the NodeMCU for RX, TX.
###Using 1 bit audio can be kind of awesome,…
and i have a tool that sort of does much of it for you… if you can tolerate the abrasive low-fi sound. <3
#demo
playback of voice and then music and run-time remixing of pre-recorded music.
#tutorial
I also made a 37 minute file detailing every step of getting the audio onto the micro controller etc.
#hackaday
Just wanted to show off the article that was written about it on hackaday, yay! Oh wow, dated 2014 ! Time does certainly fly by.
#oh and the speaker
Was salvaged from a random DAB radio I found.
