Band saw blade kinked
@woodtechs very sorry - I was sawing a small piece in the band saw which got caught and the band has now bent. It may be repairable by filing the tooth off or bending back. Have put a note on the machine saying don’t use for now. Can pay for new band if need be, I’m here for the rest of the day
I’ve swapped this out for a 1/2" we had on the wall and removed a rather scary note dictating improper set up which may well have contributed to your issue.
The machine is set-up running as it should, will take a look at getting the rip blade back into service next I’m in the space.
Won’t be able to get it as good as a new undamaged blade but it should be salvageable.
What did the scary note say?
