Attention users of Ruby (Trotec alternative to JobControl)
Hi. I upgraded the software on Wednesday.
On the Prepare screen there is now a timer button.
Once you select your material, you can press the button to get a time estimate.
Several people have asked if you can add many designs to the job (i.e. import several files and cut them all at once).
Turns out you can’t do this on the Design screen, but you can on the Prepare screen.
  1. Open each file in the design screen.
  2. Make any changes required.
  3. Press Create Job.
  4. Return to the Design screen and repeat for any files
  5. On the Prepare screen, drag and drop multiple jobs from the left sidebar onto the grid.
Thanks Brendon - 2 significant changes that I have definitely been wanting!
Probably something I am doing wrong but I couldn’t connect to Ruby at slms-05.local:2402/ from within the SLMS network via wifi… Is it possible that our Ruby application is down? Or do I have to start it somewhere?
The laser PC has to be switched on, and fully booted - Ruby runs on that machine :+1:
You also have to ensure that the laser control is pointing to Ruby and not JobControl.
Notification tray (bottom right)
Right click on Ruby icon
Laser Mode = Ruby
I realize this is an old post, but with all the above i couldnt get the remote login to work. “Site cant be reached”- It seemed there is no host / server running and yes i did all of the above. Any pointers? Thanks!
Hi - The URL might be different after the PC change, change the Tools page.
You shouldn’t need to remote onto Ruby, as the actions you need Ruby for (other than importing designs if you don’t have a USB etc.) should only be done when stood next to the laser (placing the design on the material etc.)
Thank you - I was trying to prepare my job while someone else was on the laser - so the new url would be awesome to do that. I think it just needs some sort of mapping to the url because, I found out it does work with the ip address, which currently is https://10.0.4.117:2402/login
