Ashford Sampleit Loom - 16 inches
Included with the loom are a 7.5 dpi (30/10cm) reed, two 46cm (18in) shuttles, a threading hook, warping peg, clamps and a 20 page colour step by step weaving booklet. Also a piece of scrap yarn.
Condition Notes
New - loaned from @Maz
Induction and Training
Full instructions on how to use are in the booklet in the cardboard box.
Or watch this video:
https://www.youtube.com/watch?v=B0aFlG7294w
Maintainers
Risk Assessment
Identify risks
State control measures
Before Use
Please note in the calendar if you are planning on using it, and try and finish your weaving in one session.
Secure the loom and the winding pole properly to each end of the table before setting up the warp
During Use
You’re going to be sitting for a while, make sure to sit comfortably. When winding the loom forward, make sure to release the back temporarily so you don’t break your fabric or the loom.
After Use
Make sure to pack all the loose bits in the box, and put the main loom back on the shelf.
Maintenance
May need a bit of re oiling every now and then, if any parts break they can be reordered, @Maz knows how to put it all together.
References
https://www.youtube.com/watch?v=eHd45bqE3Jw
https://www.youtube.com/watch?v=7oqxiPZ3ul8
https://www.youtube.com/watch?v=CzLgm-iT6NI
https://www.youtube.com/watch?v=Zjm4mYJ8ZSw
