Dear all, Outside, crap picked up and binned leaves dealt with, Clean room , a bit of a clean around , things put away , a bit of a dust down ,Main table tidied up and cleaned , Toilet area, sides washed and bleached, soaps topped up , bin emptied , hoovered and mopped , kitchen area, dishwasher filled /emptied /cleaned , cutlery,crockery,cups put away, appliances checked and cleaned , sides wiped down , fridge checked , bins emptied, hoovered and mopped , soaps topped up, Screen printing / laser cutter/mini CNC,s area, sides wiped down , a bit of a dust around , bins emptied, washroom hoovered, laser cutter cleaned, a good hoover around, Textiles and 3D printing area, sides tidied up and wiped down , a good dust around, things put away , a damn good hoover around
A few things to note-
Someone left the big CNC computer on
Someone left the metal lathe on.
There is rather a nice amplifier under the computer desk in the clean room with no name or tag on.
I found a phone on the sofa and put it on the right hand side of the big tv .
There is a mixing desk on top of the electronics area with no name on it .
The small heater in the sofa area may need looking at there seems to be a bump on the cable .
The boots that were by the front door have turned up under the screen printing vac table, please be warned a colour change will be immanant if left here.
Any painting in the textiles area please use newspaper (thank you )
When is the laser cutter getting fixed ( I have people asking me )
Many thanks to a new member asking this morning if I needed any help it was very thoughtful but im mostly a do it yourself kind .
4 hours and 45 mins today, back in tomorrow for arch 2.
Anything else please drop me a line. Keep well . Brian D=
Amazing work as usual Brian, thank you.
Someone left the welding area in a messy state when I got in around 15:00. The vacuum cleaner was unwound on the floor despite apparently not even having been used to clean, and the welding table was covered in debris. I tidied it when I left.
Additionally, someone left an angle grinder plugged in and switched on at the socket. This is hazardous. Please, everyone, unplug angle grinders after use.
