Hey…the area ‘could’ have been cleared so that I could’ve used the large textile tables @lewisss was eager to help, but as he quite correctly put it “I got out of bed on the wrong side” today and didn’t wanna play. Felt it better I leave before I ended up casting a grey cloud over the room!
I’m pretty sure it’s 650gsm fabric.
Also, the seams don’t need to be completely waterproof. I’m okay with a little leakage if that’s the best we can do. It’s merely a cover to stop ridiculous amounts of rain settling on the garden bench I made. At the moment the drainage holes I drilled are not clearing the water sufficiently and causing issues. The cover will hopefully put an end to this. Like I said, a little water getting in wouldn’t be the end of the world.
I think gluing the seams in place and then sewing after will be a good idea. Will make it easier to handle…hopefully!
I should be at the space around 9.30am Monday. I’ll probably have to spend about an hour marking and cutting the pattern I’ve come up with - though I’d love to run it by yourself or anyone else with pattern cutting experience first. I’ve come up with this all by myself and I have zero textile experience, so could be missing something major in my plans!
I would post pics and try to explain on here but it’s so complex I’d probably end up confusing myself and everyone else.
