I’m printing a labradoodle tree ornament for a friend of a friend. The support needs look pretty ruff (heh). Any chance anyone has some advice on slicing params I could tweak to get the material down and lower it from being a 3 hour print?
You can paint supports and put in support blockers in Bambu Studio. You can add supports to an area such as the top loop if you feel those are needed. See e.g. video below.
How strong do you need it? If just an ornament, then you could get by with 2 walls and minimal fill - 5% even. Layer height will depend on quality you want. Consider the seam.
Rather than spend ages trying to shave a few minutes from the print time, make use of that print time for doing something else in the space….
