I can turn the handle on the lathe, but I’m not sure what tool to use to shape the end of the hook - maybe a file of some sort?
If you aren’t completely set on all wood, just ordered one of thes to make for my partner. Has an interchangeable hook.
Personally I’d draw a template on them once turned of what to cut out, then just carefully go at it with handtools to round over the top and cut out that V shape.
A coping saw would be able to remove most of the material then chisel, file and sandpaper to finesse them.
Thank you!
