Anyone know of a good spray adhesive for paper that’s oil resistant ?
I want to stick paper templates onto metal so I have a rough guide when milling parts, but the cutting fluid makes the normal spray stuff unstick after a while.
A method usually used which isn’t exactly a template but possibly helpful?is to use an ink/dye to coat the surface and then mark using a scribe
3M Photomount is stronger than Spraymount. Have you tried that?
@RichM i used some cheap stuff that was in the space but i have some red photomount. There’s blue as well but can’t remembers which is stronger
@nico.dejong.nz I want to laser print the template and stick it on just as reference. This saves a lit of time and i don’t need to use digital readouts on the mill to know roughly where i am
Red is stronger than blue.
Low strength
High strength
