well being a woodtech has its benefits, thank you to @afshind and @rosszeibari for gifting me some Zebrano from the massive delivery earlier in the week.
so here is the first little project done earlier today.
after thicknessing and jointing.
two pieces doweled and joined together.
planes down fairly well . irregular grain does mean there is some tearout similar to working with wenge
it also smell a bit like washing that has been left damp for 4 days!
Laser cut template
double sided tape to stick template to piece
Rout the internal features to depth
after routing the outside
edges rounded over
after sanding, first coat of oil
legs turned on the lathe
lead weights for the glue up
finished article
and its intended use
