Wood Lathe - DELAYED -Personal Turning Time for James. :)
(James Mouat) #1
Turning time: 13:00 - 17:00
I’ll be turning a ruined and repair bowl. Patched up an old padauk bowl that I blew off the lathe while I was first learning to turn, ruining the mortise and cracking severely in the process.
Now that we have the cole / button jaws for the lathe, I’ll be seeking to try and salvage it. It’s got some fancy pigmented resin filling-in the busted bits and has become an experiment of sorts.
Wish me luck! :smiley:
(Petra) #2
noice! was thinking of turning wood resin bowl m’self! Hope I’ll have the chance seeing yours!
… don’t you have by any chance left over pigment? I’m going to play with resin and am looking for a little smudge for project with @ozumcan
(James Mouat) #3
I have some turquoise pigment and some “old gold” pigment. It’s SUPER strong, so unless you a mixing liters of resin you only need a very small amount. I’d be happy to share.
(Petra) #4
turquoise and gold! yes please :slight_smile:
I’ll be mixing a bit, making some jewellery and also casting some plants…
(James Mouat) #5
Well if you are able to come down to the space during this time I’ll make sure to bring them with me and you can check them out. :slight_smile:
(Petra) #6
Alright :slight_smile:
(Dermot Jones) #7
Glad to see you’re taking some James time!
(James Mouat) #8
I am going to be about 1 hour late, but I will still be using my time slot.
I could not see a way to edit the booking times to reflect this.
@petra - if you are planning to come in to check out the pigments, I still have them and will be bringing them but I will be running late.
