Tips Slow Wi-Fi
There are a number of causes of slow Wi-Fi including:
- The wireless connection is disrupted due to interfecence from:
- Living in a high population density area where there are a lot of other wireless users.
- Interference from other wireless devices on the same frequency including:
- Bluetooth wireless devices including headphones
- DECT wireless home phones
- Microwave
- Distance from the wireless transmitter to your computer
- Obstacles from the wireless transmitter to your computer, walls, doors, people, etc…
- Weather patterns
- Faulty component or software on the computer or router
- Poor internet connection
All of the above can make your connection via Wi-Fi appear to be slow when loading pages. The major components you need to test are:
- Your Computer
- Your Wi-Fi
- Your Router
- Your Internet Provider
It’s quite easy to test these, but before you do to get the correct results, everyone has to stop using the internet.
1: Your Computer
To test your computer isn’t the problem, just run a speed test from another computer, if you get the same or similar results then the issue isn’t related to your computer or other factors related to the positioning or environment your computer is in, scroll down for answer A at the end.
2: Your Wi-Fi
To test your Wi-Fi isn’t the problem you again need to run a speed test, this time via an ethernet cable plugged directly from the computer into the router/modem provided by your Internet Provider.
At this point if your speed is still slow this indicates that the internet problem is with the router or Internet Provider.
If your speed is faster again this indicates the issue is with your Wi-Fi and there are some things you can try.
3: Your Router
Unless you have a spare router hanging about which with some ISPs like Virgin Media isn’t an option, you can’t swap out your home router to test, that being said it’s unlikely to be a hardware issue, so two things to try:
Power off your router, wait 10 seconds, repower it and run a speed test, if it works, great, work your way back through steps 2, then 1, if not then move down:
Reset your router, login to the control panel detailed on the box, or ask your ISP for help with resetting the device to factory settings, again work speed test, and work your way back through steps 2 and 1, else move down.
4: Your Internet Provider
Issues with slow internet connection are less common than they used to be as ISPs have had decades to improve their network, however certain ISPs like Sky / NOWTV have become very popular resulting in high demand in some areas which takes them time to catch up with.
The best thing to do here is contact your ISP and tell them you are having speed issues even on an ethernet cable, they’ll probably do this testing with you again, but they can replace the router, if this still doesn’t help it’s likely a local network issue with too many customers in the area.
ISPs in the UK all use something called a contention ratio to determin how many of their customers share a certain amount of network bandwidth, so while your connection from your home to the exchange may be a 52Mbps connection, after that it’s very expensive for ISPs to provide everyone with 52Mbps back to the internet, so they install slower but faster connections and share them amoung many customers. The ratio between sold broadband speed and actual backhaul is normally enough that no one really notices, but if you have a lot of customers in one area hammering the connection this will make everyone go slow.
Some ISPs such as Virgin Media are able to look at the network contention in your area and see if there are issues here.
If you are certain none of your home hardware is the issue and your ISP is saying they can’t fix the issue quickly, or maybe at all then you need to change ISPs, scroll down for answer B at the end.
FYI: Your ISP keep going round in circles restarting, resetting and replacing the router is effectively saying they can’t fix this, you can ask them after 1 loop of this to speak to a senior advisor but replacing a router repeatedly will not fix your issue.
Note: With internet provided over phone line it’s possible for your ISP to also verify if there are any line issues which might be causing the issue, they should do this automatically and if it is the line they’ll send out an Open Reach engineer to look at fixing this.
Fixing things
Answer A - Wireless is slow in my house
This is likely caused by interference, while people including myself list DECT phones and microwaves as possible causes, the issue is almost always caused by other Wireless networks, both yours or your neighbours.
Wireless communication is a bit like a group of people talking on Skype, when everyone talks no one can be heard, so everyone stops, and they wait a bit and then try to talk again, if done right people take their turn and everything is fine, but when you have more and more people the chance that two people talk over each other again becomes increased.
Every time a person (wireless transmitter) broadcasts it looks out for ‘collisions’ with other transmitters, if this happens both transmitters stop, and wait a random amount of time then check again before transmitting, the problem is that this could mean no one talking for a long time, then both one starts talking as a third person kicks of, restarting the proceedure again.
On computers this happens very fast but it is still an issue that gets worse with more and more users.
Some moder wireless transmitters can fix this issue, and generally lowering the power of your transmitter can help but if Wireless is slow in your house, and your list of neighbouring wireless hotspots is massive then the best opition here is a cable.
Answer B - Change your ISP
There are four categories of options for internet providers in the UK:
- Internet via Telephone Provider (ADSL or similar)
- Internet via Mobile Provider (4G/5G/WiMAX type services)
- Internet via Cable TV Provider (Virgin Media)
- Internet via Dedicated ISP line (Hyperoptic/Community Fibre/FTTP)
The most common providers of internet are those which use your home phone line, in the past this meant all broadband providers used BT’s network regardless of the name on the bill, just like with Gas and Electricity, however this isn’t the case any more, your phone line goes back to an exchange where multiple companies can fit their own equiptment, this means in some areas you might be able to pick from a number of suppliers and get away from the aforementioned contention issue by switching to a different provider who has their own equiptment in your exchange.
To check this you can enter your postcode on SamKnows Telephone Exchange Check:
https://availability.samknows.com/broadband/exchange_search
In the section titled ‘LLU operator presence’ you’ll see green checks next to the options in your area, for example in my area the marks indicate Edge Telecom, Sky, TalkTalk and Vodafone. If I was with Sky and having issues I could switch to Edge, TalkTalk or Vodafone and be pretty well guaranteed I’d move away from contention issues, unless those ISPs also have contention issues.
The positive here is that those ISPs would be under 14 day cooling off period clauses so you could cancel if you weren’t happy.
These types of services can be good for occasional use or mobile use but they’re not recommended for every day working, if you are using one of these ISPs you can switch but you should really consider moving to one of the other options.
Virgin Media are really the only option here for most of the UK, and certainly London, if you can’t resolve the issue with VM then switching to one of the other options is your best best.
These services are pretty uncommon outside of new builds and blocks of flats, but if you are in a block of flats and don’t have this find some neighbours to register interest with companies like Hyperoptic, their services are incredibly fast, 1Gbps which typically results in less issues with contention as it’s rare for anyone to use their full network speed for very long. Downloading even an entire hard drive full of data would take less than an hour at full speed.
If you can, always pick this option.
