Does anyone know where I can buy a single sheet of veneer for doing marquetry? Need a light colour. Maybe Canadian maple or birch. Don’t really have time to order online, so would like to know of any shops that sell that sort of thing.
Also, any @lasertechs have an idea of the settings needed to do a small bit of marquetry work? Specifically I’m looking for a starting point to experiment with. I’m using oak and I think the depth of the engraving will need to be under 1mm, so any ideas as to the power & speed settings needed?
Also, I’ll be using the same file to cut out the veneer inserts. I’m assuming if I were to use the file at the same scale of the engraving, the kerf would mean the inserts would be a little too small to fit the recesses. How would I best negate this? Maybe enlarge the shape by 1% or something?
The only person I know of who’s successfully completed any marquetry is @smorgasbord, so if you’re reading this, would you be able to shed any light please?
Cheers.
