TREND T33A WET AND DRY M-CLASS DUST EXTRACTOR 1200W - 240V
SPECIFICATIONS
- Rating: Trade
- Power input: 1200 watt
- Voltage: 230 volt
- Dust category* M
- Tank capacity 25 L dry, 17 L wet
- Bag capacity 16.5 L
- Sound pressure Lpa 82 dB(A)
- Max suction 160 mbar
- Flow rate 23 l/s
- Negative pressure 16 Kpa
- Cable 5M
- Hose 5 M x 39mm OD
** Vacuum cleaners of dust category to EN60335-2-69 for dry vacuuming of materials of exposure limit volume > 0.1 mg/m3 that are hazardous to ones health.*
- Vibration <2.5
- Weight 8.34 kg
- Acoustic pressure Lwa 94 dB(A)
- Dimensions 625 x 380 mm
- Power tool adaptor OD Taper 32 to 36 mm
- Synchronised Power take off 1500w max, 60w min
Condition Notes
New (August 2022)
Induction and Training
Owners
Before Use
During Use
After Use
Maintenance
References
