Wasn’t happy with the join so saw it open.
Realised the issue was that one piece is warped making it hard to get the correct angle to join.
Finally got it joined nicelyWasn’t happy with the join so saw it open.
Finally got it joined nicelyBand Sawed out the outline of the swamp ash part
Routed the electronics channel drilled the channel from the electronics channel to where the electronics cavity would be Glued on the top Planed the top flat Routed out the neck pocket and the pickup cavities but need a different router bit to route deeper in the cavitiesLooking lovely mate
now done the round over, the jack socket and the electronic cavity as well as the body mount holes in the neck pocketThe progress i got up to so far. Not sure if i will put inlays in this guitar . May leave it plain ebony. Undecided currently
Neck plate design (to be engraved by lazer cutter)
Once this guitar is finished I’ll probably try and make one of my own design at some point. I may use this opportunity to use the laser cutter to make a dante inferno inspired fretboard inlay
