Would anyone know if it were possible to string multiple fairy lights together to run off of one power source?
Specifically, if I wanted 300 bulbs, but all split into groups of 30 with normal spacing, but these groups all being around a metre apart.
Essentially it would go plug > 1m cable > string of 30 lights spaced out at an inch or so (however they were manufactured) > 1m cable > 30 lights > 1m cable……and so on.
Is this possible, and if so, how easy would this be to achieve? Could I buy a string of 300 and just chop it up and insert le the of cable to achieve the gaps?
Thanks in advance
