Hey guys,
I’m at the space, trying to open the shutter when I scan my FOB I get a short beep followed by a long beep.
Any ideas?
Hey guys,
Any ideas?
Hit the red button than the green and touch your fob again, if still not working you have to wind it up manually with an 8mm hex bar
Thanks for fixing this, good thing I found out when trying to open and not when closing
It tends to break when you close it:rofl:
Yea, same issue from last autumn - this is the first time he has used it since then…
I have added him back in…
Cheers,
Andy
Hey Paul, your last successful shutter tag in was in July. You were likely caught up in this issue.
Anyone who has not used the shutter since Nov 19th, 2022 should double check it still works for them.
