I thought I drop that here too as it might be useful to some of you and it’s completely hackable.
https://flashair-developers.com/en/
You can hack the wifi settings and run various wlan mode by just changing the wlan config on the card and the UI is completely customisable
I found out about it will browsing online and at first I didn’t knew you could hack the wlan settings used it a bit the way they recommend on the manual but it was so restrictive I gave up. Than I found that article
and subsequently found more info about it
http://www.extrud3d.com/flashair
None the less to says that uploading my gcode to the printer without needing to take out the SD card copy and bringing back as made things much easier added bonus learning about how to tweak the UI is quiet fun.
