Request for help - Custom bed frame plan validation and advice and possibly induction to the metal mitre saw too
Hello @MetalMitreSaw
Please help validate this plan for a custom bed frame.
This is my first metal project ever. I have taken the basic metal shop induction, but not been introduced to the metal mitre saw.
I’m planning to fabricate a custom-sized bed frame from milled aluminium 40x20x2mm:
  • 45 degree mitred cuts on all corners to form a flat horizontal bed frame.
  • The rails and end caps will be joined at each of the four corners with 5-6mm L-shaped aluminium brackets internally with rivet nuts. Alternatively, I could use something else that can fit inside the 16mm cavities, or tig weld it.
Frame Orientation: 20mm surfaces are on top and bottom and 40mm surfaces are facing in and out of the frame.
Cut list:
2× outer rails, 1862mm – 45 degree mitre both ends to meet the end caps
2× end caps, 1177mm - 45 degree mitre both ends to meet the rails
2× internal ribs, 1822mm to fit between the 2 end caps – no mitre required
BOM:
1 x 5000mm: 2 outer rails and 1 end cap = 4901mm
1 x 5000mm: 2 internal ribs and 1 end cap = 4821mm
Cut plane: Mitre (blade swivelled 45° in plan, blade itself staying vertical): the cut face is the tall 40mm plane, the diagonal seam shows on the top and bottom 20mm faces, and the two outer 40mm faces meet in a clean vertical corner line.
Handedness: On each rail and end cap, the two mitres must angle toward each other — mirror images — so the outer face is the long point and measures the full 1862mm or 1177mm.
Please advise and thank you in advance!
Cheers,
Rod
Ok. A quick scan looks good. There’s only so much a list like this can tell you though. Heads up … don’t rely on having the TiG available. It’s not atm…
In the space this evening if you’re around and want to chat it through…
Thanks Dave. Let me know the approx time you are there and i will swing by. Can you do a mitre saw induction this evening or are you busy?
Question to all metal work projects: When i was in the shop for the basic metal induction, I noticed a box of short lengths of scrap extruded aluminium with holes drilled in - looks like off cuts. Does this belong to anyone, and please can a use a couple of pieces to practice on the chop saw?
many thanks :slightly_smiling_face:
rod
I’m going to say 7pm to be safe… hoping to get there earlier, but I can’t rely on myself managing that.
Most of the metal lying around the metalshop is available for members to play about with. If it’s marked or is a large chunky bit, it’s likely to be someones. We need a better system…
If you can drop by I’ll show you around the saw and point out what materials are definitely available for you to use…
I’ll aim for 7
thanks
Dave
A massive thank you for your time this evening! As discussed, attached is a .pdf file for the bed frame i’m designing. I checked for sanity, however, I can’t attest on the quality of the metal engineering from Claude Fable 5!
I have a .scad file, but that file type is blocked from uploading here.
Bed_Frame_Drawing_rev10.pdf (119.9 KB)
Cheers,
Rod
Updated the frame design - much simpler now:
Bed_Frame_Drawing_rev12.pdf (118.7 KB)
