Recommendation sought: One-off water or laser cut steel or stainless steel in London?
Tags: #<Tag:0x00007fa4a2ac6e28> #<Tag:0x00007fa4a2ac6ce8> #<Tag:0x00007fa4a2ac6b80> #<Tag:0x00007fa4a2ac6a18>
Hello SLMS,
I’ve been a silent member for many years due to health issues and the fact that I now work in W. London, so I never even get anywhere close to you - but I hang on to the dream…
I need to find a supplier of a steel or stainless steel sheet of 2mm or 3mm thickness, approx. 1m x 0.7m with 24 holes cut or drilled in precise location. The kind of job a laser-cutter would do, or even nicer: a water-jet.
I looked at Fractory but their minimum order seems to be 10 units, which is 9 more than I’ll ever need. Can someone recommend a maker or professional supplier who could run this as a one-off without charging the world?
Many thanks!
Hanry
I have nothing useful to add but a virtual fist bump.
In North London, but worth an ask?
Sure is, thank you very much!
@RichM might well have a lead
I use https://microkerf.co.uk/ but they have a minimum order value
Send a dxf to rich@muchhadhamforge and I can get you a quote
Very kind, Rich!
Will email right away!
I’ve emailed you back!
Try Good Empire in Streatham - https://goodempire.com/
