Phase II design brief - edit me!
An experiment in group decision making - a collaborative design brief :
This editable post [can admin make this a wiki post please :smile: ] is the Design Brief for Phase II of the building work.
For the first week it’s open season - any one can add as many items and headers as they want, but add only - no deletion at this stage , even if one persons item contradicts the other, add what ever you want as long as it’s in the style of a Design Brief - a short summation of what (not how) you want / need*.
Then after a week we see what we have. If there are any completely contradictory items, we deal with this through a vote, then the rest we prioritise though an order of preference vote (the mechanics of this to be figured out in more detail when we get the results in but probably Doodle).
Once we sign off the brief we can give it to a select team to come up with the best solutions.
*If you want to explain or elaborate on what you’ve added use the thread below but only short summations in the document please.
** You can type a ² on windows by holding ALT and typing 0178
SOUTH LONDON MAKERSPACE:
PHASE II
DESIGN BRIEF
South London Makerspace (SLM) is to refurbish the second half of its space. This half of the space is to house workshop(s) of some description, as there is all ready a ‘clean’ working space in the front of the space. This document outlines the nature of those workshop and other types of utility spaces.
General Infrastructure
The space will have:
  • power
  • lighting
  • data
  • plumbed sink
  • storage for
  • infrequently used tools.
  • power tools, small and not so small
  • sewing machines and associated accessories
  • members’ projects
  • piles of random junk that spawn and multiply in the darkness
  • our collection of vintage electronic equipment (might be umbrella’d by ‘junk’ category)
  • μMeet kit: boxes of shared components
  • BBQ equipment
  • Construction stuff: plumbing electrics bits and bobs
  • Some kind of compressed air - useful for LOADS of stuff
##Activities & Facilities
This section describes the activities that are planned for the space and what facilities they will require and what space they require
Woodwork
TOOLS
  • Shadow boards with hand tools
  • Workbenches x 4 @ 2m² each (more like 10m² when circulation/working area included)
  • Pillar Drill 1m²
  • Crosscut Saw & guide bench 1.7w x 0.6d
  • Band Saw 1m²
  • CNC Machine m² Shopbot Buddy 1.83m x 1.25m, or 1.83m x 2.5m when extended for 8’x4’ sheets
  • Turning lathe - 1m²
  • sharpening station, eg tormek t4
  • Router table
  • Disc/belt pedestal sander 1m²
  • EITHER Seperates:
  • Morticing machine 1m²
  • Joiner 1m²
  • Thicknesser 1m²
  • Table saw 2m²
    • a pluge saw with guide rail could substitute table saw
  • Spindle Moulder.
  • OR Combi tool
  • eg. Schepach bestcombi
INFRASTRUCTURE
  • Dust extraction (dedicated 23A circuit likely required or just plug it in )
OTHER GEAR
  • Material storage
  • Storage for adhesives and finishes
  • Storage Lockers (for what?)
Metal Workshop
Basic metal working facilities:
TOOLS
  • Anvil or anvil shaped bit of metal (there is a Difference)
  • Small lathe 2m²
  • Pillar Drill 1m²
  • Metal belt sander 1m²
  • Mill 1m²
  • Sheet bender
  • Guillotine
  • Vice
  • Pipe / bar bender
  • Small electrical furnace for getting bits of metal very hot / molten
  • think size for jewellers in first instance, moving up to a couple kilos.
  • Other jewellers stuff
  • Mini Anvil.
  • Magnification things
  • Teeny tiny hammers.
INFRASTRUCTURE
  • Power supply for furnace
LaserCutting
TOOLS
  • Laser Cutter 2m²
  • Computer & desk / chair 1.5m²
  • Storage for material stock and free offcuts
INFRASTRUCTURE
  • Air venting*
    *has it’s own extraction
  • Extractor to be isolated somewhere else for sound.
  • Extractor to be kept with laser cutter for ease of use and maintenance
Screen Printing + can double up for etching, linocut, stone lithography table
An area for screen prints to be prepared
TOOLS
-guillotine
-stacking drying rack, 1x1.5m footprint (ideally dust free space)
  • please can an experienced printer add tool list and surface area required
  • Table to work on A0 (841 x 1189mm) sized prints comfortably
  • drying line
  • screens
  • pressure washer and basin to wash screens?
INFRASTRUCTURE
  • Basin or large plumbed-in tray?
  • Darkroom for exposing masks?
Dark Room
  • Somewhere dark to crack open film and do a bit of photo developing.
Assembly Area
An area that for the assembly and finishing of larger projects, e.g. beds, dining tables or smallish rockets
  • Spray booth for application of finish
TOOLS
INFRASTRUCTURE
AREA NEEDED
  • a marked out area of floor 2.4m x 2m in a non-dusty area
Ceramics Area
A space for working with clay: a great rapid prototyping/thinking material
TOOLS
  • Small table
  • Selection of moulding tools
  • potters wheel
  • Tub for storage of clay
  • Shelf or cupboard for air drying work
  • Kiln (only necessary if ceramics is taken beyond the play/prototyping level
INFRASTRUCTURE
  • Basin, possibly with speciality clay catching trap?
  • Power supply for kiln
Plant and growing space
Projects that want to deal with algae, plant matter and growing things
TOOLS
Grow lamp
Hydroponics pump
I have already printed the chimney.!
INFRASTRUCTURE
space
power
A collapsing table area
Getting Rid of Stuff
Yes, that is an activity! We need to control junk…especially ‘useful’ junk.
It could be a series of bays marked with “time till disposal” and the gear is moved on a bay each week until disposed, unless someone claims it for use.
NEEDS
  • A series of storage bays with signs on
Another Activity
A brief description
TOOLS
INFRASTRUCTURE
Casting things
n.b. in resin or low temp metals for now
Tools:
Vacuum forming mechiean
  • vacuum chamber for evacuating silicone, or lost wax moulds.
  • pressure chamber for doing the exact opposite.
  • centrifuge, for flinging things into moulds.
Infrastructure:
  • Some kind of pad to do hot things on that won’t burn straight through the floor.
  • Extraction. Lots of Extraction. And a small fume cupboard
BICYCLE MAINTENENCE
INFRASTRUCTURE
  • Wall mounted Bike Stand?
    TOOLS
  • Freestanding Bike Stand
  • Bike tools!
Vaccum forming
Vacuum forming is a simplified version of thermoforming, whereby a sheet of plastic is heated to a forming temperature, stretched onto a single-surface mold, and forced against the mold by a vacuum (suction of air).
see Wikipedia on vac forming
TOOLS
  • Vac forming frame and heating element
INFRASTRUCTURE
  • dependant on compressed air/vaccum from other infrastructure project
##Overarching Needs
  • Visual connection between all areas of the arch. For safety and community
  • Design for versatility. In order to maximise use of space
  • storage space in snug
##Noise Pollution
The construction of Phase II should prevent too much noise disturbing those in the clean space. Fire regs may mean some noise is audible but not enough that people in the clean space can’t be heard talking.
Noise pollution should also not disturb neighbours out the back. The solid acoustic wall at the back is a condition of our tenancy.
##People with Disabilities
  • The space should be accessible for people with limited mobility.
  • The workshop spaces can’t at this stage cater for chair users.
  • At this stage, the workshop spaces should, where practical cater for chair users.
##Pests
As pretty much anywhere in London, rats are not far away and should not be encouraged to make the arch their home. In practice:
  • Don’t attract them by never leaving any food or scraps unsealed in the space when empty. Bins don’t count, they will be (and have been) got into unless firmly closed.
  • Keep them out by ‘sealing’ the perimeter of the arch. Sealing here is a pragmatic matter, something effective to a rat-size. Currently the lean-to is outside of this perimeter; the rear wall has wire mesh fitted, and the door to the lean-to should be shut when the arch is empty.
    -We could extend the perimeter by adding mesh around the lean-to.
  • If rats are detected in the space, traps are to be left and the rats disposed of. So far, the gutters have been practical for this.
    get a cat called Gerald.?
##Applicable Building Regulations:
###Fire
Phase 1 room is the “escape room” because it has the exit door in it,
You must not pass through more than one door between anywhere in the building and the escape room.
Therefore:
@members @dalph0, @gordonendersby, @matt, @aabdulshakur, @peter_hellyer, @laurent_muchacho, @conomara, @MARKSE, @richard_aw, @peter, @RichM, @Stuart, @andreas_varotsis, @tobyspark, @ben, @adamjpage, @unknowndomain, @Dermot, @jan_evetts, @emile_swain, @tomnewsom, @russ, @ianzwilson, @barrylillis, @marksteward, @andrewdblack, @eklecticmonkey, @michael, @stef, @squaredoffagain, @AussieFred, @stefanoromano, @biffbangbosh, @KarlS, @jwhelpton, @sarahbarber, @hanno_halonen, @GordonC, @Matthew_Stannard, @Willybood, @richard, @SarahJ, @rabiuy, @davidceriwilliams, @Rory_Yeung, @Matthew_Ian_Clarke, @mandola, @Felix_Ingram, @Tim, @david, @l_shearer, @Slack, @wilfe_gorlin, @Glenn, @Rob_Morandi, @Rs1771, @helenemartin13, @Alireza_Datoo, @Watcher, @GoldieRatio, @afshind, @Gui, @beccaleece, @andrew_d, @judithdeberker, @beck, @Ana_Nieto, @Rachel, @timahrensbach, @Rob_Darbyshire, @omsoc42, @AliceMayDesigns, @ampem, @leo_mchugh_uk, @Marco_Pagliari, @pip, @RoB, @GutlessWonder, @alleghe87, @Tarek.Abidia, @yulia_silina_linkedi, @gerard_50, @ronantuite, @ryan_keegan, @joeatkin2, @tyson, @Bex, @payam_be, @Michael_Cannone, @pmcnv
We need to work on the list .
Woodwork
Thicknesser
Joiner
Moryicing mechean
Bench sander
Table saw
Dropsaw bench
Bandsaw
Router table
Drill
Mettel work
Drill
Mill
Lathe
Vice
Sheat bender
guilotean
No sander
What about printing and darkroom?
amd then there is the issue of storage
Edit the brief! :smile:
Not with my spelling…
Slightly altered the statement about wheelchair users - would be better to think inclusive than not, accepting the caveat that this isn’t always practical.
This is great. I’ll put some stuff in later.
I wonder under what heading to put things like: ‘good sightlines between all areas’, and ‘enhance versatility of whole arch’ which could be seen as overarching wants…
Was it your statement you altered?
Users should be aware that there is no sophisticated edit clash detection in Discourse. If you click Save, your changes are saved. If someone else clicks save afterwards, their changes will overwrite yours. Both versions will be in the edit history, however.
bear with me, I’ll fix my mess
EDIT: boom. done.
20 posts were merged into an existing topic: Phase II design brief - discussion
Darkroom?
This topic is about speccing what things we want and it should be, not arguing back and forth on that the ideas… I’ve separated those posts out.
You’re right. Apologies for taking it off-track!
Can you then please find a volunteer to go through your replies and add them to the brief please Joe? Point is to avoid loosing stuff in the chain. Your comments are valid and worth adding, no matter how badly spelt, but if they aren’t in the brief they won’t be included in the final edit. Ta, n.
I’ll do this
Expanded Pests section. Apologies for being prescriptive rather than needs-based, but that’s how it came out. Can edit if need be.
Yes, the idea was to express the need/want in the wiki, flesh it out here, and engage in traditional battle over in the ‘discussion’ thread.
Bump!
Only a few days left… Now is a good time to read through what’s in the first post, and if you can think of any conceivable activity/need/want/use…then add it!
Outlandish isn’t a problem here.
It’s shaping up quite nicely :smile:
Three days left
@tomnewsom - any chance you could get some specifics about fire regs in the brief above? I put a heading in but not an expert, would be useful to get it in I think.
ALL MEMBERS - any more ideas for PHASE II, get editing!
@dalph0, @gordonendersby, @matt, @aabdulshakur, @peter_hellyer, @laurent_muchacho, @conomara, @MARKSE, @richard_aw, @peter, @RichM, @Stuart, @andreas_varotsis, @tobyspark, @ben, @adamjpage, @unknowndomain, @Dermot, @jan_evetts, @emile_swain, @tomnewsom, @russ, @ianzwilson, @barrylillis, @marksteward, @andrewdblack, @eklecticmonkey, @michael, @stef, @squaredoffagain, @AussieFred, @stefanoromano, @biffbangbosh, @KarlS, @jwhelpton, @sarahbarber, @hanno_halonen, @GordonC, @Matthew_Stannard, @Willybood, @richard, @SarahJ, @rabiuy, @davidceriwilliams, @Rory_Yeung, @Matthew_Ian_Clarke, @mandola, @Felix_Ingram, @Tim, @david, @l_shearer, @Slack, @wilfe_gorlin, @Glenn, @Rob_Morandi, @Rs1771, @helenemartin13, @Alireza_Datoo, @Watcher, @GoldieRatio, @afshind, @Gui, @beccaleece, @andrew_d, @judithdeberker, @beck, @Ana_Nieto, @Rachel, @timahrensbach, @Rob_Darbyshire, @omsoc42, @AliceMayDesigns, @ampem, @leo_mchugh_uk, @Marco_Pagliari, @pip, @RoB, @GutlessWonder, @alleghe87, @Tarek.Abidia, @yulia_silina_linkedi, @gerard_50, @ronantuite, @ryan_keegan, @joeatkin2, @tyson, @Bex, @payam_be, @Michael_Cannone, @pmcnv, @alex, @tom_tibbits
Done.
