Missing rollers for the vinyl cutter
Does any know where the rollers for the vinyl cutter are.
They’ve gone missing.
They are metallic tubes about 600mm long 25mm diameter and with bearings at each end.
Found ! Need a couple of new bearings on them, though
Where did you find them, as I thought I’d found them in the snug at the very back and @frasco said it was only 1 of three.
I found 2 under the vac table
Do we have a full set now?
