Hi,
This probably seems super simple to most of you, but I need some guidance on how to do some relatively simple construction
I’m planning to make a box for my project by cutting out 6 panels on the laser cutter. I can figure out the panel sizes needed in order to make the required internal dimensions. By this point I have pretty comprehensive CAD drawings of the panels and the cutouts etc.
How would I go about fixing the 6 sides together to make a box, with the added constraint that the rear panel must be detachable in order to assemble and change the internal components ?
I’m sure there’s more than one solution and with different properties and qualities - all options will be considered
Thanks,
Doug.
