Machining edge to stainless steel boot scraper
Hi, I want to make some architectural stainless steel work for a project. The idea is to machine a flat bar into a boot scraper.
Is this something that could be achieved in the metal workshop?
Photos and dims attached.
Thanks!
Daniel
Should be achievable but stainless is hard
Thoughts in order
  1. Have a go with a file and do it by hand - maybe not on googling
  2. Grab an angle grinder and have a stab
  3. Go to the mill when the techs are free and ask them to tilt the head of the mill to give you the angle, and then machine the chamfer - not an operation to do without a techs sign off, it takes a while to set it back to vertical - not sure how hss would do here? Might need some testing - @metaltechs
Any reason you want to go for stainless?
Blued mild steel woul work I think.
Also, no matter what material, I’f you support it only on one side and you use your foot on it, you will bend it
Other than that, what @James_Nahajski said!
Stainless was the preference because any painted or galvanised finish would wear off when boots are scraped on it. One end also slots into timber post and needs to not corrode to help protect the timber post.
It would be supported on both sides - one into a post base and the other into a wall so should be ok.
Is stainless feasible on the mill?
Yes. I’m uncertain of the need to tilt the head when you can tilt the workpiece. But then as with all these sort of things there are many surprises hidden along the way.
Ok, so what would the next steps be? I am not inducted on the mill yet. So that is step one.
Next step is to order some stock?
When ordering stock, be careful what you wish for….
For machinability 303 - not really weldable
Gummy to machine, work hardens 304 - weldable
Bitch to machine 316 - corrosion resistant
Free machining and magnetic 416
Pick your poison…
First time I’d go 303 / 303se - its easy peasy and you’re not welding it
