Hi All
I can’t seem to find any recent threads relating to the potential purchase of a CNC machine for the space, so I thought I would start afresh. All comments welcome! A long post.
I believe that a CNC machine would be useful for most members of the space - with regular cleaning and a detailed set of induction material, a CNC would be useful to all areas of the space, from circuit boards and dense wood to big chunks of metal. With this in mind, I think there are two potential routes to take.
Route 1 - Build It!
This is very much inkeeping with the Makerspace ethos of DIY to the extreme. It’s also the cheapest option, although not necessarily the most accurate method of doing things. Designs are readily available, as are some parts. I’ve listed some pros and cons below.
Pros
- Cheapest method - a medium sized mill that can do foam accurately (+/- 0.5mm) is under £1000.
- We can build it ourselves - the joy of making!
- Custom design means that members will be able to service the machine more readily
Cons
- Inaccurate - with some very fine tuning, +/- 0.1mm should be OK - anything more accurate might be a little too ambitious!
- Parts can be a little hard to come by/have long lead times
- Wood capable machines are more expensive.
- Light (1mm) Aluminum engraving would be OK - but no cutting. No steel, brass or any other metal.
I have some experience with building a foam-capable CNC at home. It’s certainly doable, but not altogether practical.
Route 2 - Buy It!
I think that purchasing a small/medium sized CNC would work best as a long term investment. Although yes, a new shiny machine always catches the eye, it solves most of the problems in Route 1, but is far, far more expensive.
Pros
- Wood and Metal (steel) capable
- Accurate (in my experience) to about +/- 0.025mm
- Capable of small, repeatable production runs
Cons
- Damn expensive. A small, high quality CNC mill starts at about £4500, but can easily run to £40k.
- Heavy.
My vote would be to bite the bullet and get something high quality/mid sized (the Tormach 770 comes to mind. Of the 19 people I know who own one in the US, I have only heard 1 bad thing and that was it was too heavy for my buddy Jerome’s truck).
But - that is only what I’d do. What route would you take? Is there any money set aside for a CNC? Do both of these options suck? I’m more than happy to take the lead on this project for research, getting training and delivering inductions.
- Rob
