Leaking tap in phase 2
Hi someone might already be onto this, but in case not, the left hand tap above the sink in the back is leaking from where it’s joined to the pipe. It’s made a bit of a lake under the sink. Can I turn off the water supply to just this sink?
If you follow the pipe from the tap back in the direction of phase 1, you will come to the isolator valve. You will need a flat-blade screwdriver to close it (or a coin) as there is no handle.
Done thanks. It was quite a mission to get to past the mountains of crap.
We really need to do some tip runs! Id be happy to come down early one Saturday or Sunday and do a few runs back and forth if someone could help me load the car and figure out what can go and what needs to stay.
