toliver38
(Tyler Oliver)
14 November 2016 14:09
1
I’m looking to make two or more laser engraved tap handles for my kegerator. Right now I have two concepts I’m floating
Create laser cut ply cutouts and glue to a large wood block to give it an engraved look
Laser engrave a larger complete tap handle a few mm deep to get a more finished look.
@lasertechs can we engrave solid wood? If not, I will go with the first concept.
tomnewsom
(Tom Newsom)
14 November 2016 14:11
2
Avoid using resinous softwoods, and you’re all good. I’d imagine you’d want an attractive hardwood for this anyway.
Also bear in mind that we do have a rotary attachement, which requires a bit of setting up but will let you engrave on cylindrical/conical surfaces.
toliver38
(Tyler Oliver)
14 November 2016 14:14
3
Awesome. I heard about the rotary attachment but I think for the first two I’m going to go with a tapered flat surface. Thinking of doing some oak with two different stains or possible painting the engraved section.
