Laser cutting project
I got a little project on the back burner (portable 3D printer) but no time available to dive into the laser cutting, than I thought instead of getting the part cut by a laser cutting services I could make SLMS and it’s members benefit from doing it.
This is open to any @Members or the @Trustees to see if they can use the project as support material for laser induction. I will provide material 600x400x6mm sheets, pay for laser cutting time and give £40 for the job to the member or donation to the space.
The job on itself require you to cut all the part from the pdf below dxf files are available from the git repo if needed. You might need to re-arrange the piece to fit the sheet size provided.
https://github.com/Mowi/MowiPrinter/blob/master/Lasercut%20Parts/Mowi%20Frame%205.8mm%20v6%20Flat%20.pdf
There is no rush or obligation and this is purely a call to see if anyone will be interested in doing it I’ve already got a job quote from a laser cutting services and if no one want to do it I will use them.
Hi yes I’m very keen to help out on this project.
I would also be.
Thx Peter, Marco as accepted to look into this and started preliminary work.
