Morning Petra
You are a great teacher!! Thanks. Is there a password to get into the laser cutter computer?
Laser cutter
thanks Lesley,
it’s written on the bottom frame of the screen.
Me too!! I did one yesterday evening - very exciting, a trifle stressful. Thanks Petra
Does the laser cutter cut mother of peal, and can it be used to engrave/cut sheet metal?
Laser cut/engrave mother of Pearl not sure. Cut/ engrave metal definately not. Have you seen mother of Pearl engraved before?
Hi, does this include anodised aluminium?
I’ve spoken to a laser tech who said engraving anodised alu was ok and have a project in mind.
I can’t see it would do any harm really, but likely your milage will vary more dramatically than you’d hope.
In truth, the restrictions are : 1) Nothing in the machine that will damage the machine (reflecty stuff) 2) Nothing in the machine that will cause a really unpleasant mess (sugar) 3) Nothing in the machine that will fill the space with toxic gas (Chlorinated plastics, Formaldehyde etc).
I have heard of mother of pearl being laser cut and engraved.
Does it have to be a special kind of laser cutter to cut or engrave sheet metal?
To engrave sheet anodised aluminium is possible with our 80w speedy 300, to cut even thin sheet metals requires far greater power… raw metals engraving is not possible with this machine.
I beg to differ! Now we have procured some Cermark this is pretty simple.
I have so far managed successful metal engraving on Nickle and Copper, I’ll be giving it a go with stainless and brass next time the lasers free and I’m feeling motivated.
The settings vary greatly from metal to metal, I had to go half the speed for copper as for nickle to get a comparable quality engrave.
Interesting. Would be interested if it would engrave steel of any sort next time you try
Please showcase your results, I can tell you now that raw aluminium even with cermarc is not possible… I spent an hour trying today…
Stainless steel is no problem but aluminium is something else…
I would have uploaded pictures but at present I have no means. I’ll borrow a member’s phone next time I’m in the space.
Here are some pictures of my testing with cermark spray on stainless steel.
Can supply the settings next time I’m in the space. The quality of the stainless and finish make a big difference to the finished mark. This was cheap stainless steel plate so finish is good but not fantastic. The hello parts are done with a fibre laser
Hi, I’m now a member how do I go about booking an induction on the laser cutter?
Hi Paul,
Your payment should clear with us any day now
You need to log into your membership account and link it with Discourse, that way you’ll see members areas and be able to sign up for inductions – which are in the admin section here on Discourse
