hello, does anyone have any tips as to why the laser cutter is not cutting through acrylic? I have checked all the settings and it is only cutting half way through and the laser is ‘pulsing’?
thank you…
Is the red dot focused?
Lens clean?
What are your settings?
I’ve found I sometimes get “pulsing” when printing from inkscape using a resolution of 500dpi(?) or above. That setting appears on the Trotec print settings window, near where you can choose the colour mode, etc.
Hi @Elizabeth99,
If you need a speedy response to your laser queries please use @lasertechs in the post.
I have run a test cut through 10mm acrylic with no problems. I bet it’s down to your material settings.
Set the print preferences as they are on the tools set on discourse and recreate you material settings using the info sheet as a guide and try again.
Let me know if you need any further assistance.
Test cut below.
Good luck.
Jonathan
Thank you for all your replies. I went home. But I did all of the above. maybe it just wasn’t my day on the laser cutter. see you soon have a nice evening.
