Laminate ply forming workshop @ the Institute of Making
This is what I’m doing and where I am today…
Discourse has loaded the photos in a bit of a random order I’m afraid. Rearranging them into a sensible order is left as an exercise for the reader.
How are the blue formers shaped?
Hot wire through foam I reckon.
We are using a big bandsaw
http://coolgameuk.com/lava-v100-premium-vacuum-sealer-89-p.asp
Blue foam is good stuff, never seen anything moulded to it before, melts in vac former, how does the ply retain its shape after, you just leave it for a while?
It’s 3 or 5 layers of 0.8mm birch veneer. You’re making your own plywood, effectively.
More work from today
Wow nice stuff
I was planning on doing some with some oak I have lying around, but using two shapes + clamps. The vacuum thingy looks way better though :grin:
It is. It clamps everything with a totally even clamping pressure and you only need to make one mould.
