Let me preface this by saying that I have no idea what I’m doing.
So, I need to make a vibrating table, for which apparently I need a vibrating motor.
According to this page you can turn any regular motor into a vibrating one by placing some off-centered weight on the shaft of the motor.
I had a DC motor from an old hoover which I’m trying to repurpose for this project, however as you can see from the photo, the shaft doesn’t really look as long as it should be. I can’t seem to be able to remove the metal casing either. So, it will be challenging to attach anything to the shaft given I haven’t got much of a shaft to work with
Does anyone know how I can go about turning it into a vibrating one? It’s also possible that I’ve got this all wrong and the thing I’m looking at isn’t even the shaft, in which case please let me know!
Thanks in advance
