Steinel HG 2320 E
Precision digital control. Electronically controlled HG 2320 E hot air tool. 2300 W, digital temperature setting by joystick from 80 – 650 °C, temperature indicated in 10 °C steps on LCD display. Infinitely variable air volume regulation from 150 - 500 l/min and 4 memory programmes to save desired settings.
Power: 2300 W
Temp. Range: 80 – 650 °C
Airflow Rate: 150 – 500 l/min
Condition Notes
Bought by SLMS - December 2023
References:
Instruction Manual:
2961_110059279_BDAL_HG_2120_E_HG_2320_E_26_SPRACHEN.pdf (3.3 MB)
Data Sheet:
143319_Data sheet - 4007841007386 - HOT AIR TOOL HG 2320 E.pdf (472.5 KB)
Heat shrinking cables:
Maintenance:
Replacing the power cable:
