Guitar speaker cabinet
In the midst of a 2x12 guitar cabinet build based
Routed half the main frame but need a 1.5mm spacer to line up the rest
I’ve been using a router jig
It was designed to use some unknown probably uncommon router bit so I am having to use a 5/8 " template but and a 1/2" with a 5/8" bearing
The plywood will rip out at the front so I have used a sacrificial piece to prevent this
Routing finished
Are you doing early fender style and using solid pine? Got plans on what speakers you’re going to use?
It’s birch plywood. I haven’t found any plans anywhere.
The dimensions are based on a Sills Super Fatboy 2x12
I am looking to put two kemper kone speakers into here once they are released to use with my kemper
Main carcass glued together.
Edges rounded
Looking good!
Handle holes routes
It’s getting closer to being done. I tend to start a new project before I finish another one :see_no_evil:
Very nice work indeed.
Nearing completion !!
Beautiful!
Great job!
Very nice. Nice colour for the fabric etc, a little retro looking.
