My first attempts at face turning. Had great fun and learned a lot…I was after the straight sides. The big one was glued to scrap piece and then sawed off.
I wanted to make them deeper but i found when the tool tip extended beyond the anchor point on the tool rest it was tricky to control…is there a technique to fix it? A curved tool rest?
Bowls are sanded down to 400/600 grit…I found get better results sanding on a lower speed…is that the best way? The end grain on the sides didn’t sand do well and are bit pitted.
They are left untreated…I may wax them later.
Big thanks to @Beth for the hands on demo and @Mouat for the many tips.
