Another little bit done by @Joeatkin2 and me! Maybe slower but we are carrying on!
Bootiful work boys!! I’ll hopefully be there to lend a hand during the week.
I thought we were going to use the bigger sink to collect water from the screen printing?
Regardless don’t forget we need to have space behind it for a light box where that back splash is, and a rail to hold the screen in position.
Cool!!
Yes. Would the bigger sink fit there?
When it was decided to put the sink there, was it measured for the long sink?
Now you tell me…
I thought it had been decided, well we have a temporary stand to keep the wrong sink on
Genuinen mistake sorry
If not thats fine, it should be okay with that run off but we should consider the back box carefully as you need to be able to spray water onto the screen with a pressure washer with it angled back on a backlight, might be nice to consider a front to the tap to keep the water splash inside?
Have left 2" for the light box and put the run off for that reason. we can put the other sink on it if you want and it can be reversed if needed
I think the other sink is too long for that orientation. Would need to be along the north wall if using the other one.
Okay well it’s great work, lets keep it as is, but would be good to have a way to catch water from running off the front if possible.
Do I correctly sense that this is constructed from wood in the vintage log pile? #lookhopefulanditmightcometrue
I’ve got a feeling that the sink isn’t big enough for screen printing, and the long one is too shallow for brush washing etc.
Let’s dig the other one out
There’s three?
Man, you guys are SMASHING it today.
just off cuts
Looking at the photos they are not even sinks.
No, I meant let’s get the second one out to see how it fits.
