On the konmari train and had a clear out, some items that I’ve been hoarding that seemed a shame to recycle / dispose but wouldn’t go to a charity shop, listed below. If you want them, say so and I can leave in the space for you with strong promise you’ll pick them up promptly.
Counter - this is a decent size, about 120mm wide not including key shaft etc. Counts in up in 5s though.
Does not fit the makerspace printer, 1.75mm white, of unknown age but still sealed.
Metal Enclosure with some holes cut in, about 150mm x 70 x 50 at a wild guess (didn’t measure any stuff when I took the pictures and they’re now not next to me sorry)
Modelling clay, also good for mould makers?
O rings imperial
Assorted
A couple springs - maybe could be subsumed into metalworking
Jubilee clips
Hard grey rubber ends
Metal Gears - surface rust and they have a little threaded grub screw hole
PCB spacers, loads of them, approx 50mm long M3 or 4
Washers - M3, 4 & 5?
Stainless steel zip ties.
Assorted M4 bolts and some M3 grub screws
If ppl don’t want them happy to donate to the space for general use?
