Hold on!
You read the topic and went yes please didn’t you?
After an investigation of the laser this morning and insertion of a new lens, I was able to successfully test cut the following 3 tests found from files on the desktop. Varying materials, processes and thicknesses as seen below.
This does not mean the laser is reopen for use…
None of the projects tested showed any issues but, I would like to do some more testing…
What I’m suggesting is that if you have an urgent need for a laser cut project, a @lasertech assists to monitor the machine and hopefully your project is completed. Both parties benefit.
As I know this will require my time or another @lasertechs, I’m initially looking for someone who is a bit flexible with time in the space.
The prusa build frames may be a good one?
The user with the wedding bits?
Let us know below and the @lasertechs will pick a few.
We are aiming to have the testing concluded by Monday the 15th and hopefully have the machine reopen for use by/before then.
If you have any questions, drop them in the chat.
Jonathan
