ive been making a blue tooth speaker in an old radio.
sure some have you have seen it.
well its pretty much finished now.
only problem is when i turn it on, it makes a really really loud on signal.
you cant change the volume before you connect to the bluetooth.
it makes a really loud noise when the blue tooth connects. then you can turn it down once youre connected. its really annoying.
no documentation came with it.
i cant find any online.
i joined http://electronics.stackexchange.com/ but they told me this wasnt something that should be on their forum. ive only used coding stackexchange before, so it was my first time on the electronics one. the guy wasnt very helpful and said it wasnt realted to their forum. having never used it before i was unsure if he was correct or just being a troll…
…any way, any one know a good electorics forum or have any experience with programming these boards?
i want to be able to:
- turn the start up volumn down
- change the bluetooth device name
- its got setero output. is there a simple way to change it to mono on one spearker using settings / software on the board?
board details:
