we/they came up with a super quick pipeline for getting the battens up.
Nothing genius, just a few little things strung together.
Note, we are looking to reuse the battens behind the existing old lining thats there.
This old lining needs to be taken down, leave battens if they are secure.
you will need:
Drill press
SDS drill/extension lead (drill chuck on this not the best, needs tightening every so often)
Cordless drill screwdriver
hammer
appropriate sized screws, plugs drill bits
safety googles
two people on scaffold towers
optional extra person on drill press, saves time
0:Remove anything in the brickwork or hammer in, so it won’t interfere with battens or lining
1:We are drilling the holes through the battens, using the drill press. Holes are about seven or eight to the batten, one near each end.
2:Lift batten up to roof, hold in place manually. Use reg drill to mark roof at one end through batten.
We are lining the battens up so they have the smallest chance of hitting mortar. So the long edge of
the batten should run just beside a long mortar joint but not on it, see previous battens for example.
3:remove batten, use SDS drill to drill brick, insert wall plug, replace batten and screw one end into roof, do
same for middle and other end, wall plugs can be inserted straight into brick since batten is flexible and cant be flexed out of way. The holes should be nearer one, or either edge of the batten, this allows us to put the screw holding the lining onto the batten in the center of the batten and not hit the the screws holding the battens into the wall
4: after start middle and end screws, screwed through the batten, into the wall plugs/brick, batten is now in place.
Remaining holes in bricks can be drilled through the remaining empty holes in the battens.
We put a bit of tape on the drill bit of the SDS drill we were using cos its easy to drill to far into the brick behind batten
5:To get the wall plugs into the bricks behind the batten, just insert wall plug into batten, tap in with hammer, so
the wall plug is flush with the surface of batten, then insert screw into the wall plug and tap the screw so the
wall plug is pushed into the hole in the brick.
6: screw in
@peter_hellyer change if u think the wording is bad, or if missing info
